My NP231 (90, 4.0, AX15) has been getting a good workout with all the snow we've had recently. So far I've had 2 instances where I've unsuccessfully tried to go from 2HI to 4HI. The first time I pulled the lever to the detent and didn't have 4 HI. Cycled the lever again and it went in. This afternoon was the same story except I was able to pull the lever an extra 1/2 back after driving a few hundred feet and felt it pop into 4HI. I'm guessing bad bushings on the T-case linkage.
Any write ups on this and/or P/N for the bushing kit? I'd imagine it's an exercise similar to changing wiper linkage bushings. My search results have all been related to 2 to 4WD conversions.
I've never done a replacement of the bushings, but I've taken them apart with screwdrivers before. They pop in and out, I would assume that they can be changed out easily, In fact I would guess that getting the linkage off of the body and trans is going to be harder for you than changing the bushings.
you can also adjust the linkage. take off the plastic cover below the tcase hande. i believe there is supose to be .125 (1/8") from the handle to the stop/bracket when its engaged in 4lo. in your hayes manual it tells you how to do it.
