Cut out ALL bad metal weld in new steel. paint over with some type of rust stopping paint or bed linner
Brandon
mine was almost exactly the same as that. I cut off the frame top and fit in some 1/4" plate inside the frame, flush with the top, and then sheeted the whole thing with 12ga on the floor and shaped some 20ga to rebuild the hump (it's what I had). I didn't put the frame top back on but I did put the side stiffener back on. I cut it back to about the rear seat posts before I found enough good metal to weld to. From this:
to this, after seam sealer and before POR-15. the other brackets are to mount my '98 XJ buckets.
