duane300z Posted January 6, 2011 Share Posted January 6, 2011 i replaced all the brake line in the rear and from where the two lines go up along the gas tank cut them out and ran new lines. Replaced master cylinder front calipers wheel clyinder .the brakes feel fine but light stays on . anyone help 1989 comanche Link to comment Share on other sites More sharing options...
Darren Posted January 6, 2011 Share Posted January 6, 2011 Is your foot still on the pedal? Link to comment Share on other sites More sharing options...
mjeff87 Posted January 6, 2011 Share Posted January 6, 2011 If you replaced the rear lines because of a blowout, there's a switch in the prop valve in front of the MC that probably tripped...you may need to reset it. Push down on the pedal, steadily and hard, until you hear a "click". That will be the switch resetting, and the light should go out. Jeff Link to comment Share on other sites More sharing options...
TrailReadyMJ Posted January 6, 2011 Share Posted January 6, 2011 Stuck/Faulty e-brake switch? Link to comment Share on other sites More sharing options...
duane300z Posted January 7, 2011 Author Share Posted January 7, 2011 i heard the click but light is still on. If you replaced the rear lines because of a blowout, there's a switch in the prop valve in front of the MC that probably tripped...you may need to reset it. Push down on the pedal, steadily and hard, until you hear a "click". That will be the switch resetting, and the light should go out. Jeff Link to comment Share on other sites More sharing options...
maddzz1 Posted January 7, 2011 Share Posted January 7, 2011 Try pulling up on the ebrake foot pad. Sometimes the spring wears out and the pedal will fall enough to put the light on. Only a few things control the light, low fluid, e-brake, and the switch jeff mentioned. Link to comment Share on other sites More sharing options...
XXLMJ Posted January 7, 2011 Share Posted January 7, 2011 Don't know if it will help, but some times my brake light switch under the dash falls out of its little hole and the lights stay on. Link to comment Share on other sites More sharing options...
