comanche13 Posted January 3, 2011 Share Posted January 3, 2011 I have replaced all the idler bearings but now there is a new squeak and I can not find it but if i spray silicon lube on the belt the sound stop for about 10 seconds (the belt is not to tight or loose either). Any ideas what I should fix I put a screwdriver against the bearings and they all sound good I am out of idea's. Link to comment Share on other sites More sharing options...
jimmy21669 Posted January 3, 2011 Share Posted January 3, 2011 Same hear, then I realized I was fat... :rotf: Seriously though, water pump? Link to comment Share on other sites More sharing options...
comanche13 Posted January 3, 2011 Author Share Posted January 3, 2011 no it seemed fine also Link to comment Share on other sites More sharing options...
Geonovast Posted January 4, 2011 Share Posted January 4, 2011 How's your balancer looking? Link to comment Share on other sites More sharing options...
comanche13 Posted January 4, 2011 Author Share Posted January 4, 2011 some of the rubber is starting to come out i was going to change it when i do my front crankshaft seal Link to comment Share on other sites More sharing options...
Geonovast Posted January 4, 2011 Share Posted January 4, 2011 That's probably your issue. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 4, 2011 Share Posted January 4, 2011 Somethings is squeaking in my belt Trouser mouse? :dunno: Link to comment Share on other sites More sharing options...
Akula69 Posted January 4, 2011 Share Posted January 4, 2011 Somethings is squeaking in my belt Trouser mouse? :dunno: :rotfl2: Link to comment Share on other sites More sharing options...
alleydog Posted January 5, 2011 Share Posted January 5, 2011 I bet if your crank seal is leaking, you have oil on the belt. Just run it till you get the new seal in it, then make sure you clean all the pulleys off with brake cleaner and compressed air before you put the new belt on.Buy a good belt, I use goodyear, but thats up to you. Link to comment Share on other sites More sharing options...
comanche13 Posted January 5, 2011 Author Share Posted January 5, 2011 yeah I bought mine from lordco forget the brand don't know if it is a good quality or not Link to comment Share on other sites More sharing options...
