sinned96 Posted December 5, 2005 Share Posted December 5, 2005 I have a chance to get a rolled 87 4x4 shortbed with a 6cyl and a five speed. Will the trans work on my 86 2wd 4cyl 5sp. Should I just put the 6cyl in my 86? The 87 has 3.07 gears can I use my 4.10 rear and have the front axle changed to 4.10? Who make the gears for it. Any thing else I should know? Link to comment Share on other sites More sharing options...
square Posted December 5, 2005 Share Posted December 5, 2005 NO output shaft is different YES go for the 6 YES rear will bolt right on randys ring & pinoin, Yukon and lots more it may be cheaper to find a front with 4.10's then to re-gear Link to comment Share on other sites More sharing options...
87manche Posted December 5, 2005 Share Posted December 5, 2005 Putting the 4.0 in your 86 is a pretty big project. How badly was the 87 rolled? You'll need the whole front clip basically. Radiator mounts, hood I believe fenders too. They lengthened the engine bay in 87 to accomodate the 4.0 You can regeaer the front axle, but the cutoff point for the D30 was 3.33 or 3.73, you'll have to get a new carrier for it to go 4.10. Might want to just consider a locker at that point. Link to comment Share on other sites More sharing options...
mjeff87 Posted December 5, 2005 Share Posted December 5, 2005 Trannies won't swap easily, but you could make it work if it's an AX15 behind your 2.5 Better option is to pull everything from the 87 and swap it into the 86 (engine, harness, 'puter, trans and t/c) You can leave the rear axle in, and just swap the 2WD front beam axle with a 4.10 D30. Add driveshafts and enjoy.... Jeff Link to comment Share on other sites More sharing options...
Pete M Posted December 5, 2005 Share Posted December 5, 2005 The transmissions behind the 2.5L/2.8L and 4.0L do NOT interchange. They have a completely different bolt pattern on the back of the engine. If the rolled truck was really, REALLY cheap (free or next to it), I'd probably still buy the wreck, but I'd hesitate swapping the drivetrain into the 86 unless I had a whole bunch of time on my hands. Jeep on! --Pete Link to comment Share on other sites More sharing options...
mjeff87 Posted December 5, 2005 Share Posted December 5, 2005 As a rule, true Pete. But, you can mate an AX15 to a 2.5L using a late model Dakota bellhousing and a machined CJ pilot bearing, and a clutch/housing from something (non-Jeep, Camaro maybe??) There's a huge thread over on Pirate with a full write up from a guy who did it. I've toyed with the idea for mine, but that'll be a "down-the-road" project :) Gotta keep setting goals, ya know? Jeff Link to comment Share on other sites More sharing options...
sinned96 Posted December 6, 2005 Author Share Posted December 6, 2005 So it sounds like to much work just to 4x4 my truck. Oh well no reason to tear up a perfectly good running 107k MJ. I guess it time to build the 455 for my Pontiac. Link to comment Share on other sites More sharing options...
mjeff87 Posted December 6, 2005 Share Posted December 6, 2005 Not too much work at all, if you don't use those parts from the '87. Just keep your 86, swap your tranny for a 4WD version, add a transfer case and a front axle, plus driveshafts :-D Got any decent junkyards near you that you can get parts from? Jeff Link to comment Share on other sites More sharing options...
