kro10000 Posted December 18, 2010 Share Posted December 18, 2010 In preparation for the snow I finally got down to swapping in my xj d44 to match my front ratio. I finished last night and ended up driving it 250 miles with no problems. What a difference 3.55s make vs 3.07s. Anyway my only problem is I am still using the load sensing proportioning valve and the bracket that bolted to the d30 does not match up to the d44. What have you guys done to solve this problem? Link to comment Share on other sites More sharing options...
Pete M Posted December 18, 2010 Share Posted December 18, 2010 I ditched the sensor. course I also completely redid the brake system at the same time, dual booster and all. Link to comment Share on other sites More sharing options...
kro10000 Posted December 18, 2010 Author Share Posted December 18, 2010 Well for now the valve works, so there isn't really any reason to get rid of it. Id like to do a dual booster swap too, but I'm a poor college student so anything like that just isn't in the cards for me right now. Link to comment Share on other sites More sharing options...
Pete M Posted December 18, 2010 Share Posted December 18, 2010 you don't have to do one to do the other. I just happened to do it all while I had the chance. :D and I didn't care if the valve worked or not. I wanted it and the rusty brake lines gone. fewer things to fail. try asking in the classifieds for the 44 bracket. :thumbsup: Link to comment Share on other sites More sharing options...
ComancheKid45 Posted December 18, 2010 Share Posted December 18, 2010 which bracket are we talking? The 1 with the stud on it to attach the rod to the diff from the valve? Link to comment Share on other sites More sharing options...
kro10000 Posted December 18, 2010 Author Share Posted December 18, 2010 It attaches to the bottom of the rod and has two holes on it (at least mine from the d35) that two of the differential cover bolts go through to attach it to the axle. Link to comment Share on other sites More sharing options...
jeepcoma Posted December 19, 2010 Share Posted December 19, 2010 I reused my D35 bracket, I had to drill a new hole. It worked pretty well but since then I've removed the rod and just put the proportioning valve at "full brakes". I haven't had any issues with lockup when braking hard. I'm going to dump it entirely in the spring when I redo the lines, everything is pretty crusty looking. As Pete said, fewer things to fail. Link to comment Share on other sites More sharing options...
