91coMANche Posted December 12, 2010 Share Posted December 12, 2010 I searched and found out that the resistor pack can cause the blower motor to run only on high. Mine just doesn't turn on. Sound like a resistor or motor or something else? I can get a new resistor from rockauto but I am wondering if I need anything else? Link to comment Share on other sites More sharing options...
jpdocdave Posted December 12, 2010 Share Posted December 12, 2010 Have you done any testing? If your blower motor does not work at all, start with checking the fuses, then check to see if you have power and ground at the blower motor when it's turned on with the key on. There's a good chance the resistor and everything is fine, and there's power and ground at the motor, and the motor is just no good. Link to comment Share on other sites More sharing options...
91coMANche Posted December 12, 2010 Author Share Posted December 12, 2010 Ok so just hold a volt meter to the wires going into the blower motor? Is the fuse in the panel under the driver or under the hood? Any idea what the fuse is labeled as? Link to comment Share on other sites More sharing options...
jpdocdave Posted December 12, 2010 Share Posted December 12, 2010 it shouldn't be hard to figure out what fuse is what. And if you are using a volt meter you can put the ground lead on the ground wire, and the positive lead on the power wire and see if you get voltage. If you don't, you need to break it down and see if you're missing power or ground by testing separately. Link to comment Share on other sites More sharing options...
SouthShore440 Posted December 12, 2010 Share Posted December 12, 2010 open the hood and tap the blower motor with a wood stick or what ever you have handy. do this with key on engine off, and make sure the blower switch is on. Link to comment Share on other sites More sharing options...
91coMANche Posted December 13, 2010 Author Share Posted December 13, 2010 I was able to only check the resistor and the fuse today. The "blower" fuse is a 30 and is good. The resistor is in there loose with only 1 screw. Now here is the confusing part...the HVAC unit in the dash doesn't light up with the radio and dash lights. Is there a specific fuse just for the HVAC unit? I had a fuse blown out that said something like "passenger" something or other and replaced that but I have no idea what that did. Tomorrow I'll be able to check power to the blower motor. Its too cold to not have the blower work and only be teased by the little bit of warmth coming out of the bottom vents on "heat." Link to comment Share on other sites More sharing options...
