randimal Posted November 26, 2006 Share Posted November 26, 2006 My XJ has a 6 inch lift using RE drop brackets (they stopped the death wobble). I'd like to move this suspension onto my MJ, but the MJ has a slightly different control arm mount. Is it still possible to use the RE drop brackets? Looks like either I would only use the front half and do a homemade brace, or I would possibly cut off the stock brace on the MJ control arm mount. Maybe then the whole RE assembly would fit. Let me know if you have an answer. Link to comment Share on other sites More sharing options...
Twisty Posted November 26, 2006 Share Posted November 26, 2006 everything from the font suspension of the XJ will work on the MJ. pretty much everything from the cab forward is compatable between the two. except for a few things like seats, etc. Link to comment Share on other sites More sharing options...
Eagle Posted November 26, 2006 Share Posted November 26, 2006 The brace on the MJ control arm mounts is welded onto the OUTSIDE of the "frame" rail at the pockets. The brackets fit up inside the control arm pockets. I don't see how the frame gusset could interfer with the drop brackets. I had a Trailmaster kit with brackets on my 88 MJ, it was on when I bought it. It's my understanding that the RE brackets are copies of the Trailmaster, so I think they should fit. Link to comment Share on other sites More sharing options...
pingpong Posted November 26, 2006 Share Posted November 26, 2006 I ran this very same setup on my rig. I even used the stock upper and lower control arms with no issues at all. The only thing is you can't use the support bracket that goes from the LCA pocket to the tranny x-member bolts, Link to comment Share on other sites More sharing options...
Oizarod115 Posted November 27, 2006 Share Posted November 27, 2006 yeah RE sells the dropbracket kit in the 6500 kit (5.5" kit) the only difference is that you don't need the extra brace they sell for XJs cause our CAs are already braced... work done for you. i can't wait to get my RE kit. Link to comment Share on other sites More sharing options...
randimal Posted November 27, 2006 Author Share Posted November 27, 2006 Thanks. I thought that was how it worked. I was pretty sure the drop bracket would work. I just wasn't sure about the brace. Link to comment Share on other sites More sharing options...
BARILLMS Posted December 4, 2006 Share Posted December 4, 2006 I just bought an '88 Manche and it has the RE LCA drop brackets on it.. so I guess they work. They're for sale if you're interested... I'm doing long arms this winter and won't be needing them. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted December 4, 2006 Share Posted December 4, 2006 I just bought an '88 Manche and it has the RE LCA drop brackets on it.. so I guess they work.They're for sale if you're interested... I'm doing long arms this winter and won't be needing them. On EBAY??? If so I think I saw them!!! CW Link to comment Share on other sites More sharing options...
CEThomas Posted December 4, 2006 Share Posted December 4, 2006 Dumb question, but what are drop brackets and what are they used for? Charles Link to comment Share on other sites More sharing options...
CEThomas Posted December 4, 2006 Share Posted December 4, 2006 I found the answer :oops: Charles Link to comment Share on other sites More sharing options...
