btm24 Posted December 10, 2010 Share Posted December 10, 2010 What is a good transmission to use for the my 4x4 swap? right now I have a 2wd 89 with the 4.0 I6 dana 35 rear end. don't know if that was a help. Thanks Brandon Link to comment Share on other sites More sharing options...
jimoshel Posted December 10, 2010 Share Posted December 10, 2010 What tranny do you have now? Link to comment Share on other sites More sharing options...
jimmy21669 Posted December 10, 2010 Share Posted December 10, 2010 Two choices for manual: BA/10 or the AX15.... Ummm....I'm gonna go with the AX15 If you have an automatic, AW4. Link to comment Share on other sites More sharing options...
btm24 Posted December 10, 2010 Author Share Posted December 10, 2010 sry I forgot yes auto. I am not sure at what transmission I have now Brandon Link to comment Share on other sites More sharing options...
Pete M Posted December 10, 2010 Share Posted December 10, 2010 there's only one trans you could have. AW-4. :thumbsup: Link to comment Share on other sites More sharing options...
btm24 Posted December 10, 2010 Author Share Posted December 10, 2010 Ok then that makes things easy huh? thank you Brandon Link to comment Share on other sites More sharing options...
Myron Posted December 11, 2010 Share Posted December 11, 2010 Make sure the front end you put in is geared the same as what you are now. Should be 3.55 and your transmission donor should be the same being a 4.0. Link to comment Share on other sites More sharing options...
btm24 Posted December 11, 2010 Author Share Posted December 11, 2010 Make sure the front end you put in is geared the same as what you are now. Should be 3.55 and your transmission donor should be the same being a 4.0. Thank you but I allready know. The only thing I did not know is that thwre is only one transmission I can use which is great. And I am going to be running 4:10 gears with a ford 8.8 rear end. :D Brandon Link to comment Share on other sites More sharing options...
