86ComancheXNate Posted December 9, 2010 Posted December 9, 2010 Ok I've had my truck for a few months now. When I got it it was a mess. It seemed almost like it hadnt had any attention in months. Well right after I bought it I got the oil changed replaced the plugs and wires, and the distributor cap, rotor. Well now its about time for another oil change and I was wondering if I should do anything else while I was at it. I was wondering if I should: Do a transmission flush? and Replace the rear diff fluid?
ParadiseMJ Posted December 9, 2010 Posted December 9, 2010 Yep, Replace all fluids if you haven't already. Drain and fill tranny, don't flush. Assuming you have an AW4. Flush & fill coolant Both diffs Flush brake fluid Flush power steering fluid. Clean things up. Very important to maintain all fluids on a regular basis unless you want stuff acting up and/or failing
comanche12 Posted December 9, 2010 Posted December 9, 2010 make sure flush everything to have a good tune up. my jeep have BLACK brake fluid right now. lucky i just find it out by today. I'm gonna flush it out tomorrow
86ComancheXNate Posted December 9, 2010 Author Posted December 9, 2010 Yep, Replace all fluids if you haven't already. Drain and fill tranny, don't flush. Assuming you have an AW4. Flush & fill coolant Both diffs Flush brake fluid Flush power steering fluid. Clean things up. Very important to maintain all fluids on a regular basis unless you want stuff acting up and/or failing Ok to start with draining the fluids. How do I drain the tranny, rear diff, and brakes? And what should I use to replace the fluids. I have an auto tranny with the 2.8L v6 2wd. My rear end is an AMC 20 as far as I know my brakes are stock
comanche12 Posted December 9, 2010 Posted December 9, 2010 Yep, Replace all fluids if you haven't already. Drain and fill tranny, don't flush. Assuming you have an AW4. Flush & fill coolant Both diffs Flush brake fluid Flush power steering fluid. Clean things up. Very important to maintain all fluids on a regular basis unless you want stuff acting up and/or failing Ok to start with draining the fluids. How do I drain the tranny, rear diff, and brakes? And what should I use to replace the fluids. I have an auto tranny with the 2.8L v6 2wd. My rear end is an AMC 20 as far as I know my brakes are stock dot3 for brakes fluid rear 75w-90 but use 75w-140 if your doing overhaul often i don't know about fluid for auto tranny? :dunno: maybe ATF?
ParadiseMJ Posted December 10, 2010 Posted December 10, 2010 Ok to start with draining the fluids. How do I drain the tranny, rear diff, and brakes? And what should I use to replace the fluids. 1. Buy a manual. It'll give you the basics...and it's all very basic. 2. Brakes - Dot 3 Power steering - Power Steering fluid Rear end - 75/90 - choice of brand - I use Red Line. Tranny - depends on the tranny. 3. Buy a manual
86ComancheXNate Posted December 15, 2010 Author Posted December 15, 2010 I'm pretty sure I have the AW4 tranny. When I drain the fluid should I replace the filter?
mkbruin Posted December 15, 2010 Posted December 15, 2010 I'm pretty sure I have the AW4 tranny. When I drain the fluid should I replace the filter? On an auto, yes. The filter is cheap and easy to change while you have the pan off. Fluid type Dex/Merc III Capacity: "Service" fill (drain and fill at regular intervals) is right around four quarts. "Dry" fill (fill after overhaul and replace torque converter) is around nine quarts. A "minor overhaul" will typically take five to five and a half quarts, assuming the TC hasn't been drained. Safest is to put in four quarts, idle the engine while shifting through all gear ranges (at least 30 seconds in each range to fill the valve body - 30 seconds going down and 30 seconds coming up) and check/fill as needed afterwards.
1986Comanche Posted December 16, 2010 Posted December 16, 2010 I'm pretty sure I have the AW4 tranny. When I drain the fluid should I replace the filter? No, you do not have the AW4. The AW4 wasn't used until 1987. You have the TF904. I hope this info helps.
