dead comanche
The other night i was driving home and my 89 just went dead. when i say dead, i mean the engine shut off, the headlights,turn signals, braka lights, the radio, everything else electrical just quit. the only thing this truck would do is crank the engine, not start just turn over. After checking all the fusible links, I started chasing wires to see what happened, long story short, run a new ground wire from the battery to the body.Not only did that fix the problem but, my voltmeter has stated working. I told tou all that so i could tell you this, if your voltmeter lies to you like mine has since i bought the truck, tou can fix it by running a new body ground.
Did you also replace the main negative battery cable from the block to the battery? That was most likely initially the problem. The battery to body cables are meant to be supplementary, not primary. They're good to have, but you should replace the main from the battery to the block, and probably the block to firewall strap too while you're at it.
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
