1J7FT26L2KL406505
valis
1989 Comanche SporTruck
4.0L/2WD Pukegoat 5-speed/D35/SWB
Build date: Didn't get this
Current Location: Morrisville, PA
Status: Sitting in the junkyard - soon to be crushed
Notes: Still has vinyl bench seat, vinyl floor matting, factory rear slider, rear fender flares, interior plastic minus the rear-most one. Most of the engine is still there (143K), rear axle is out and on the ground.
Current owner: Junkyard Barbie in Morrisville, PA
  • 8 years later...
*X2 TRIM STYLE X2 - VINYL BENCH
-SA Charcoal
133 Zone 33-Philadelphia
1AA U.S. Dealer Retail
5AL Low Series Tracking
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDX 5-Speed HD Manual Transmission
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAA Instrument Panel
JAZ DO NOT USE - See JP, KA classes
JBF Instrument Panel Black Bezel
JCA 85 MPH Primary Speedometer
JJA Cigar Lighter
JKB MOPAR Hood Lock
K3Z STRIPE/BADGE/MOLDING/COLOR
KDB STRIPE/BADGE/MOLDING
LAF Seat Belt Alert-Driver Seat only
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MLDG - TYPE I
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF2 18.5 Gallon Fuel Tank
PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3
QS3 DOVER GREY MET C C SECONDARY PAINT - HS3
RAA All Radio Equipped Vehicles
RAC AM MTR Radio
RCA 19 SPKRS SRT High Perf Audio
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z77 Right Front Spring Group VII
Body model TL61
Build Date 8/8/88
  • 1 year later...
