koooooooz Posted November 21, 2006 Share Posted November 21, 2006 can you body lift a mj and if you can where can i get one and will an xj body lift work Link to comment Share on other sites More sharing options...
jackel18 Posted November 21, 2006 Share Posted November 21, 2006 You can't. they're are both unibody's. you cannot seperate the body from the frame. well, only the cab forward on the MJ is a unibody, you can remove the bed. so body lift is out the question. Link to comment Share on other sites More sharing options...
ORCA Posted November 21, 2006 Share Posted November 21, 2006 :popcorn: Link to comment Share on other sites More sharing options...
feerocknok Posted November 21, 2006 Share Posted November 21, 2006 :popcorn: Link to comment Share on other sites More sharing options...
JOMJ87 Posted November 21, 2006 Share Posted November 21, 2006 :popcorn: :chillin: Link to comment Share on other sites More sharing options...
ryno1121 Posted November 21, 2006 Share Posted November 21, 2006 :popcorn: :chillin: :shake: Link to comment Share on other sites More sharing options...
pingpong Posted November 21, 2006 Share Posted November 21, 2006 I guess you can make a body lift :eek: with a few slight mods :dunce: Like cutiing and welding... and them some creative use of metal tubing :smart: But.. I don't think you would like the way it looks when you are done :brows: Link to comment Share on other sites More sharing options...
JOMJ87 Posted November 21, 2006 Share Posted November 21, 2006 Anything Is possible. Isnt JPhill doing a body drop??? That seems really interesting for lack of a better term. Cole Link to comment Share on other sites More sharing options...
pingpong Posted November 21, 2006 Share Posted November 21, 2006 Yeah.. he is making a drag truck out of it using an S-10 fram if I am not mistaken. I guess the same thing can be done with it to make a body lift Link to comment Share on other sites More sharing options...
jbhill Posted November 21, 2006 Share Posted November 21, 2006 you could but it isnt worth the time if you are lifting it. I'm building all new firewall and floor pan. the way the frame is spot welded to floor i wouldnt waste my time to raise the body on the frame rails just for some "lift" it wouldnt be stucturaly sound. I'm using a complete frame and welding 2x3 all along on the inside of the body for support. also IFS is in the front. but to answer your question, NO. Link to comment Share on other sites More sharing options...
feerocknok Posted November 22, 2006 Share Posted November 22, 2006 A whole lot of hockey pucks lined in a row. Link to comment Share on other sites More sharing options...
