1987Comanche Posted October 23, 2010 Share Posted October 23, 2010 Did any of the MJ's come with carpeting on the back wall of the cab? If so, does anyone know the rough size/method of attachment? I know the 88-98 Chevy/GMC C/K trucks were fully carpeted in the higher trim levels and wondered if the Comanches were the same. I'm planning to hit the jy tomorrow and, if I know the size, I can probably grab the grey carpeting panel from something else to cut down to size. Link to comment Share on other sites More sharing options...
Eagle Posted October 23, 2010 Share Posted October 23, 2010 SporTruck trim level did not. Chief and Pioneer levels did. Link to comment Share on other sites More sharing options...
james750 Posted October 23, 2010 Share Posted October 23, 2010 I got lucky and found one of these carpets in a JY MJ a few years ago with matching interior color. My base model didn't have one either when I got it. They are bolted to the floor at 3 points along the bottom, the factory floor carpet has three cutouts that the bolts/ brackets would go under at the back of the cab. It also rests behind the trim piece under your rear window. They have a cutout in the center for the jack handle to be able to still clip to that bracket, if your MJ still has that, if not they can be found at TeamCherokee. Link to comment Share on other sites More sharing options...
