rear axle shaft bearing & shaft replacement
Did you snap a shaft, or just need new bearings?
Non C-clip D35 bearings are pressed onto the axle, and I believe retained with a clip on the shaft. Pretty sure you'll need a press to get the old one off, and the new one on.
If you snapped a shaft, definitely don't bother buying new. Junkyard, or I'm sure someone on here has one sitting around.
Remember, D35 shafts are not the same length.
Yeah, but if I use a 84-89, won't I run the risk of having the same problem. These are some old axles. :doh:
That's why you buy new bearings.
I was only referring to buying new shafts if you'd snapped one. Personally, I'd avoid using used bearings if I could help it.
