Gunner357 Posted October 19, 2010 Share Posted October 19, 2010 1989 JEEP COMANCHE PIONEER SWB I6 4.OL 4X4 5 SEED PICKED IT UP FOR $200 IN PASCO, WASHINGTON RUNS OK ENGINE LEAK SOMEWHERE AND THE FRONTEND SHAKES LIKE CRAZY SURFACE RUST IS ALL I CAN SEE TILL I PULL THE CARPET AND LOOK THE TRUCK IS MAROON WITH RED INTERIOR GOING TO BE MY DAILY DRIVER WILL BUILD DATE RATS NEST INSIDE IS OK HEADLINER IS FALLING DOWN I FOUND THIS TRUCK IN YAKAMA, WASHINGTON IT HAS A DEATH WOBBLE I FOUND THAT THE WHOLE FRONT END IS LOOSE I HOPE ALL I HAVE TO DO IS TIGHTEND ALL THE BOLTS AND IT WILL BE OK GUESS I'LL SEE LOOK AT THE BOLTS WHAT DO YOU THINK Link to comment Share on other sites More sharing options...
JMO413 Posted May 30, 2019 Share Posted May 30, 2019 *X1 TRIM STYLE X1 - CLOTH BENCH -H9 172 Zone 72-Portland 1AA U.S. Dealer Retail 4HC Special Scheduling Condition III 5AM Largo Tracking 5KN Metro Cars of Detroit ADL Skid Plate Group ALN Body Color Bumper Group APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2X STRIPE/BADGE/MOLDING/COLOR K3E STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE8 DARK VIVID RED PRIMARY PAINT - HE8 QE8 DARK VIVID RED SECONDARY PAINT - HE8 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAE MUD && SNOW TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Body Model JM61 Build date 5/25/89 Link to comment Share on other sites More sharing options...
jdog Posted March 25, 2021 Share Posted March 25, 2021 Selling Dealer: SOUTH TACOMA JEEP-EAGLE Tacoma, WA Link to comment Share on other sites More sharing options...
