I just bought a 88 comanche today and it has a broken rear leaf spring. I was wondering if Xj rear leaf were the same length. I have a set of xj lift springs that i thought i could spring the comanche over with.
Which leaf is broken?
If it isn't the main leaf, you could use XJ leaves to replace the broken leaf and the corresponding on on the other side. Maybe toss in another XJ leaf on each side (perhaps the main leaf with the eyes cut off) if you need still more lift than the SOA gives you. If you replace an MJ leaf (maybe #2?) with an XJ leaf of the same length, you will lose a bit of height because XJ springs are designed to sit flat at XJ curb weight.
