robfg67 Posted October 12, 2010 Posted October 12, 2010 I recently had to replace my overflow bottle and during the cooling system repair process (replaced tired hoses & flushed system) the serpentine belt got wet (with antifreeze). It's been about 3 days (about 50 miles total) driving and I have a metal knocking noise at all speeds that sounds similar to the bearing in the idler pulley going bad. I didn't touch the belt adjustment at all. Also, I have NO belt squeal at either. Do I just need to give the belt more time to "dry-out" or could I have another problem? Thanks
Eagle Posted October 12, 2010 Posted October 12, 2010 The idler pulley bearing doesn't "knock" when it goes bad. It "howls" or "shrieks." Very loudly.
kyleag89 Posted October 12, 2010 Posted October 12, 2010 Water pump bearing went bad when it overheated.. :wavey:
robfg67 Posted October 13, 2010 Author Posted October 13, 2010 Well, on the drive home tonight, it began howling & shrieking very loudly. I guess I know what my next project is.
Oizarod115 Posted October 13, 2010 Posted October 13, 2010 easy enough to check, just zip the belt off and spin all the pulleys. if they all seem smooth fire it up with the belt off and see if the noise is still there, (don't run it very long, just enough to verify the engine is quiet. 30 seconds should be long enough)
