Open to Closed cooling system problem?
Well the system has been converted I think, the old radiator for a new one from a 97, new heater lines to the heater core, bypassing the control valve, but It now overheats. Do I need to change the coolant neck to a newer neck, or should I do simple things first like change the thermostat and then the water pump which is only a year old or so. The system slowly heats up, and then just continues till it overheats, never draws fluid from the overflow tank, and there is no heat when I turn the heat on. So my assumption is that coolant is not getting into the block at all? sound correct. Thanks for any advice!!
