Missing vacuum line. I think.
Alrighty, as I am getting things working better on the old rust bucket I ran across what appears to be a missing vacuum line. :idea:
According to the vacuum diagram in Chiltons there are only 3 things connected to the vacuum mainfold, on my MJ there are five that I know for sure where they go, and one empty socket that needs to go somewhere. :???:
Problem is I can't find anything that is should be hooked up. :dunno:
Any help would be very appreciated.
here's a pic, as this thread would be kinda useless without it.
I could not get shots of the egr solonoid or valve, but they both have lines on them already. I Have a shot of the air cleaner, which has two lines going to it, and the vacuum regulator (I think) that has two going to it as well.
Holy hell I'm a nub. :drool:
Found the vacuum line had been plugged into the wrong spot on the crossover unit by the PO. I had inputs on both ports on the bottom and on the top front, with outputs on both tops and the bottom rear. :hmm:
The top rear is supposed to be empty, but somehow the bottom front got plugged in there. (and looked like it belonged)
Why I did not see that at first I have no clue. :oops:
Thanks for the help folks, she runs much better with out having the vacuum system just kinda sucking air. :thumbsup:
