Car RamRod Posted November 15, 2006 Share Posted November 15, 2006 Just building up a little bumper for my MJ, nothing bomb proof, but an improvement over stock. Let me know what you think...... Brakets: :cheers: End of day 1: [/url][/img] End of lastnite: A little re-enforcment: Back of the reciever tube: Front of the reciever tube: Corner: So what do you think? I don't think I'll finish it tonite as I have to go to a wake, thursday night Ill probably have the welding and a coat of primer on. Link to comment Share on other sites More sharing options...
DansGreyMj Posted November 15, 2006 Share Posted November 15, 2006 looks good but u should trim the front even with the lights do u have any full pics of your mj Link to comment Share on other sites More sharing options...
deziped Posted November 15, 2006 Share Posted November 15, 2006 Look-un good. Good work. I'm going to build one similar to that. I like the idea of keeping the receiver flush on the front side. I,m going to put a couple tabs on bottom edge for tow points. Link to comment Share on other sites More sharing options...
Car RamRod Posted November 15, 2006 Author Share Posted November 15, 2006 looks good but u should trim the front even with the lights do u have any full pics of your mj what do you mean by this? Link to comment Share on other sites More sharing options...
jbhill Posted November 16, 2006 Share Posted November 16, 2006 looks good! Link to comment Share on other sites More sharing options...
JOMJ87 Posted November 16, 2006 Share Posted November 16, 2006 Looks great. Have you thought of putting the end caps off the stocker on the new bumper or will it look stupid. I like the box design but you said its not going to be that strong and It looks pretty dang tough to me being box and all. Keep us posted and keep up the good work. Cole Link to comment Share on other sites More sharing options...
Car RamRod Posted November 16, 2006 Author Share Posted November 16, 2006 I thought about using the stock end caps but I haven't decided. Ill see how it looks with and without them. Link to comment Share on other sites More sharing options...
Pete M Posted November 17, 2006 Share Posted November 17, 2006 Could use more attachment points to secure it to the frame if you plan to use it for extraction. Looks great though. :D Link to comment Share on other sites More sharing options...
Car RamRod Posted November 17, 2006 Author Share Posted November 17, 2006 finished all the welding and such tonite: I have a few hours between class and work tomorow, I just need to clean it all up and spray the primer.....then when I get home I'm gonna paint it. Link to comment Share on other sites More sharing options...
RandysMJ Posted November 17, 2006 Share Posted November 17, 2006 Could use more attachment points to secure it to the frame if you plan to use it for extraction. Looks great though. :D I was thinking the samething. Good job. Link to comment Share on other sites More sharing options...
ryno1121 Posted November 17, 2006 Share Posted November 17, 2006 I'm planning to build a bumper myself. What other attatchment points would you use? Link to comment Share on other sites More sharing options...
Pete M Posted November 17, 2006 Share Posted November 17, 2006 As many as you can make/find. It's all just sheetmetal up there and the front two that hold up the stock bumper don't even count as anything. They were designed with only crash in mind and are only capable of holding up the bumper until you hit something. On the drivers side I used 2 steering box bolts and another 1/2". Here's a shot of the pass side. The uppers are 5/8" and the lower (that I drilled a hole for) is 1/2". All grade 8. I'm even contemplating a 4th on each side like I originally intended. Link to comment Share on other sites More sharing options...
