64chevy Posted September 27, 2010 Share Posted September 27, 2010 I'm having trouble keeping my 1989 MJ running at idle. I have changed almost all of the emission vacuum harnesses, new plugs, rotor, cap, wires, fuel filter, O2 sensor... Give it fuel and it runs fine... Any suggestions?? Thanks! Link to comment Share on other sites More sharing options...
codymanche Posted September 27, 2010 Share Posted September 27, 2010 have u tried to adjust the idle from the throttle body it take a lil allen head i believe Link to comment Share on other sites More sharing options...
Geonovast Posted September 27, 2010 Share Posted September 27, 2010 Sticking/faulty IAC. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted September 27, 2010 Share Posted September 27, 2010 2.5L or 4.0L engine? Â I'd guess a bad IAC controller (idle air control) on the throttle body, a dirty throttle body, or if a 2.5L a bad idle motor. Link to comment Share on other sites More sharing options...
comanche12 Posted September 27, 2010 Share Posted September 27, 2010 we can't adjust the idle. correct me if I'm wrong? try clean the TPS and IAC first. Link to comment Share on other sites More sharing options...
codymanche Posted September 27, 2010 Share Posted September 27, 2010 just out of curiousity where is that iac located on the 4.0l straight 6? Link to comment Share on other sites More sharing options...
Geonovast Posted September 27, 2010 Share Posted September 27, 2010 Right next to the TPS on the throttle body. Link to comment Share on other sites More sharing options...
bigalpha Posted October 14, 2010 Share Posted October 14, 2010 we can't adjust the idle. correct me if I'm wrong? try clean the TPS and IAC first. Â You can if you adjust the the small allen screw that holds the throttle plate from hitting the TB when it closes. The PO of my truck did this when it stalled on him. Link to comment Share on other sites More sharing options...
Lemmon714 Posted October 14, 2010 Share Posted October 14, 2010 I had an issue with the MAP sense tube from the throttle body to the MAP sensor. It cracked at the elbow going up to the sensor. I replaced the tube and my idle was much better. Might not be your issue, but it is another possibility. Link to comment Share on other sites More sharing options...
comanche12 Posted October 14, 2010 Share Posted October 14, 2010 we can't adjust the idle. correct me if I'm wrong? try clean the TPS and IAC first. Â You can if you adjust the the small allen screw that holds the throttle plate from hitting the TB when it closes. The PO of my truck did this when it stalled on him. Â ah alright just make sure since i remember i saw the label somewhere on engine bay said the throttle is not adjustable. at least remember someone always said we learn something new everyday :cheers: Right next to the TPS on the throttle body. Â :agree: Link to comment Share on other sites More sharing options...
Bounty Hunter Posted October 14, 2010 Share Posted October 14, 2010 It's not adjustable, it's computer controlled, adjusting the throttle stop is an incorrect fix to a problem somewhere else. Link to comment Share on other sites More sharing options...
