Won't idle...
  • 3 weeks later...
we can't adjust the idle. correct me if I'm wrong? try clean the TPS and IAC first.
You can if you adjust the the small allen screw that holds the throttle plate from hitting the TB when it closes. The PO of my truck did this when it stalled on him.
I had an issue with the MAP sense tube from the throttle body to the MAP sensor. It cracked at the elbow going up to the sensor. I replaced the tube and my idle was much better. Might not be your issue, but it is another possibility.
ah alright just make sure since i remember i saw the label somewhere on engine bay said the throttle is not adjustable.
at least remember someone always said we learn something new everyday :cheers:
Right next to the TPS on the throttle body.
:agree:
