beepbeepmyredjeep Posted September 20, 2010 Posted September 20, 2010 Just saw this today while looking for parts for my MJ... Motionoffroad.com (who I've never dealt with, anyone??) just started carrying these this month.... Driver Side Rocker Panel: http://motionoffroad.com/catalog/index. ... ts_id=1237 Driver Side Floor Pan: http://motionoffroad.com/catalog/index. ... ts_id=1228 Passenger Side Rocker Panel: http://motionoffroad.com/catalog/index. ... ts_id=1236 Passenger Side Floor Pan: http://motionoffroad.com/catalog/index. ... ts_id=1229 If this is a duplicate post I apologize.
Carl'sMJ Posted September 20, 2010 Posted September 20, 2010 Nice... I'd be curious to see how they fit. They look like a nice floor pan. I'm currently in the process of replacing mine. I bought my replacements from Sherman Parts www.shermanparts.com and the fit is pretty decent. However, they don't come with the holes for the seat mounting studs drilled which is kind of a PITA. These ones from Motion Offroad look to have the holes pre-drilled. Price is about the same as the ones I bought from Sherman's.
sinkrun Posted September 20, 2010 Posted September 20, 2010 I think they look really good and I think he is a member on here. Used to be able to tell them you are a club member and get 10% off.
Motion Offroad Posted September 20, 2010 Posted September 20, 2010 Shoot us a PM, email us, or give us a call if we can be of any help.
87Warrior Posted September 20, 2010 Posted September 20, 2010 I see the MJ rockers are MJ specific, which is nice to see. I do not see the same for the floor pan. Are they the typical replacment pan for an XJ that requires some work to fit? How far back does the floor pan go? I started pulling the braces off of the floor this weekend and discovered holes in the floor at the back of the cab.
Carl'sMJ Posted September 21, 2010 Posted September 21, 2010 I had to buy both front and rear section floor pans from Sherman's to cover the entire floor in the cab. They're listed as matches for both the XJ and MJ. The fit is decent and has required some minor work. The part numbers were: 075-40L/R (Front) 075-45L/R (Rear)
Carl'sMJ Posted September 21, 2010 Posted September 21, 2010 Now we need cab corners! :agree: YES! :yes:
boardmanMJ Posted September 26, 2010 Posted September 26, 2010 Z&M jeeps in maumee ohio has cab corners. zach is member on here. he also has bedsides that you cut to fit. last i checked the website didnt list comanche stuff but give him a call. his place is just neat to go out there and check the stuff he has. and the cool part is he knows where everything is!!! last i herd, he had a NOS driver side MJ tailight still in the original packaging...asked a price and it was a tad bit more than i could afford :eek: Josh
Carl'sMJ Posted September 28, 2010 Posted September 28, 2010 Z&M jeeps in maumee ohio has cab corners. zach is member on here. he also has bedsides that you cut to fit. last i checked the website didnt list comanche stuff but give him a call. his place is just neat to go out there and check the stuff he has. and the cool part is he knows where everything is!!! last i herd, he had a NOS driver side MJ tailight still in the original packaging...asked a price and it was a tad bit more than i could afford :eek: Josh Thanks for the heads up... I'll have to look into that! :cheers:
btm24 Posted September 28, 2010 Posted September 28, 2010 wow they look rly nice and to say i just used scrap :shake: Brandon
