FireFighter32 Posted September 13, 2010 Share Posted September 13, 2010 Last fall I swapped a 4.0 H.O., AX-15, and an np231, along with a full wiring swap into my 89 Comanche. Almost a year after doing to the swap I am finally tying up the loose ends. My speedometer has not worked since the swap. What makes the speedo work? What could be wrong? Anyone have any suggestions? Link to comment Share on other sites More sharing options...
Silver88 Posted September 13, 2010 Share Posted September 13, 2010 Happen to know what year the guage package came from? Link to comment Share on other sites More sharing options...
FireFighter32 Posted September 13, 2010 Author Share Posted September 13, 2010 Everything came out the same 1994 Jeep Cherokee. Though at the time of the swap there were excess parts from other jeep projects, so the gauge cluster may be out of an automatic 94 Cherokee, or worst case scenario any cherokee with an non-mechanical speedo. Link to comment Share on other sites More sharing options...
FireFighter32 Posted September 14, 2010 Author Share Posted September 14, 2010 Anyone have any idea here? I don't know how the speedometers work, so I don't know what to check! Link to comment Share on other sites More sharing options...
kastein Posted September 14, 2010 Share Posted September 14, 2010 Did you swap the wiring harnesses and such as well? The signal from the VSS (sensor on the transfer case tail housing) needs to make it to the speedo/odo input on the gauge cluster somehow, if you left the stock 89 instrument panel and interior wiring harness in place that's probably the issue. It will be easier to wire that signal independently than it will be to swap the whole harness as you will need to modify the 94 XJ harness to fit an MJ. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted September 14, 2010 Share Posted September 14, 2010 Both the '89 and the '94 Speedos are driven by the speed sensor in the tailshaft of the transfer case. The '89 is mechanical (cable spins) and the '94 is electronic (all wires). If you have the complete '94 setup, it's likely something as simple as correctly clocking the speed sensor in the tailshaft in order for the speedo gear to contact the mainshaft in the transfer case. Link to comment Share on other sites More sharing options...
FireFighter32 Posted September 14, 2010 Author Share Posted September 14, 2010 Yes I did a full electrical swap. The Motor, Transmission, and transfer case are all new to the vehicle, as well as the wiring. What do you mean by correctly clocking the speed sensor in the tail shaft? Link to comment Share on other sites More sharing options...
kastein Posted September 14, 2010 Share Posted September 14, 2010 If you never took the VSS out of the transfer case and just transferred the whole thing you can disregard that part most likely. I'm betting the signal simply isn't getting from the VSS to the gauge cluster, or the +5V sensor power wire isn't connected to the VSS... where it stops is the part to figure out now. Link to comment Share on other sites More sharing options...
1987Comanche Posted September 15, 2010 Share Posted September 15, 2010 The '94 Hi-Line cluster and the older Hi-Line cluster should have the same font. Why not just swap the mechanical speedo and cable back in? The driver for the mechanical speedo should be a direct drop in for the VSS. Link to comment Share on other sites More sharing options...
FireFighter32 Posted September 15, 2010 Author Share Posted September 15, 2010 Being that I swapped everything last fall I no longer have the old speedo cable and mechanical speedometer. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted September 15, 2010 Share Posted September 15, 2010 FireFighter32 said: What do you mean by correctly clocking the speed sensor in the tail shaft? Link to comment Share on other sites More sharing options...
FireFighter32 Posted September 15, 2010 Author Share Posted September 15, 2010 Thank you for all the help. Hopefully I will be able to check this out this afternoon. Link to comment Share on other sites More sharing options...
FireFighter32 Posted September 15, 2010 Author Share Posted September 15, 2010 I looked at my t-case and I didn't see the raised dot. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted September 16, 2010 Share Posted September 16, 2010 It's not always there, but you should always put the correct number range in the 6 o'clock position in the hole. Link to comment Share on other sites More sharing options...
