Rustybucket Posted September 13, 2010 Share Posted September 13, 2010 I picked up a 87, 4.0, aw4, 2wd.. The manual windows have a small problem, if u roll them down to far, then u can't roll it back up, so u have to pull on the window so that the window regulator would catch and take the window back up, would this be easier to fix, or to just get a "new door" from a junkyard? Link to comment Share on other sites More sharing options...
Hooked Posted September 13, 2010 Share Posted September 13, 2010 I had the same problem with mine. All I had to do is lube the cable that runs the window up and down. Take your time and don't strip the gears. I used a good grade of spray grease. Don't forget to spray silicone into the felt window track, that will help clean out the grit it collects. good luck Link to comment Share on other sites More sharing options...
Pete M Posted September 15, 2010 Share Posted September 15, 2010 sometimes it's too far gone for that. but it's a fairly simple task to replace the mechanism. :thumbsup: Link to comment Share on other sites More sharing options...
Rustybucket Posted September 16, 2010 Author Share Posted September 16, 2010 how can i lube the cable the moves the window? Link to comment Share on other sites More sharing options...
