mule13 Posted September 12, 2010 Share Posted September 12, 2010 ok maybe I'm dense i'm not sure, i've read thru the threads about the load sensing valve but can't figure out what exactly i need to do to bypass it.how do i know which line in the back is the brake line and which is the bypass or whatever?i just moved to North Carolina and got noone to help me so i can't crack lines with brake applied or whatever.any bleeding i will do with a vacuum pump. looks like block 1 line on the block up front,take all the lines off the block in the rear and somehow hook the 2 rear brake lines to the line coming from the block up front. is there a t at the parts store to do this? i wanna do this because ive noticed when it rains and i brake medium to hard my front tires lock up and slide.being from florida and now in NC I'm not wanting my front end locking up next month or so when it starts snowing or the roads are iced over lol. thanks for any advice, John Link to comment Share on other sites More sharing options...
Eagle Posted September 12, 2010 Share Posted September 12, 2010 Don't mess with tees. At the front junction block, KEEP the outlet that's at the "nose" of the block. Remove the brake line from the outlet at the front/bottom of the junction block. A standard 1/2" fine thread bolt will do it, but to look good you need to cut the thread portion down. The shortest I could buy was 1" long, and IIRC the cut length was around 3/8". Check this -- if you cut it too short it won't seal. Your truck is now +/- twenty years old. Unless it spent its entire life in the Arizona desert, I wouldn't trust the brake lines. Just take them all out -- both of them. Run one new line from the "nose" of the front metering block directly to the upper end of the rear flex hose. Done. Link to comment Share on other sites More sharing options...
mule13 Posted September 12, 2010 Author Share Posted September 12, 2010 Thanks for the info Eagle. with that setup what is the braking ratio any idea? John Link to comment Share on other sites More sharing options...
mopwrd340 Posted September 12, 2010 Share Posted September 12, 2010 i just did mine works great you have to slam the brakes hard to get the back wheels to lock up . as for ratio i would say 70 front and 30 rear i have a longbed to. Link to comment Share on other sites More sharing options...
mule13 Posted September 12, 2010 Author Share Posted September 12, 2010 hey thx for the input mopwrd, what size tires are you running? Link to comment Share on other sites More sharing options...
mopwrd340 Posted September 13, 2010 Share Posted September 13, 2010 31x10.50 on stock susp Link to comment Share on other sites More sharing options...
