skitch Posted September 6, 2010 Posted September 6, 2010 Does anyone know where i can get aftermarket t-case linkage? Or the best company to get the bushings needed to realign the linkage? :???:
jvd Posted September 6, 2010 Posted September 6, 2010 Novak adapters has aftermarket t case linkages, a bit pricey though.
Comanche County Posted September 7, 2010 Posted September 7, 2010 Yeah, Novak has a cable shifter linkage that should be the cat's @#$%. Its on my MJ's bucket list.
carnuck Posted September 7, 2010 Posted September 7, 2010 Using the linkage from an XJ that is all on the tcase and doesn't pivot on the floor next to the gas pedal is the best OEM setup.
