comanche12 Posted August 20, 2010 Posted August 20, 2010 since i replaced the alternator with 100amp engine finally running but keep dying on idle speed. so i have keep feed it gas to keep alive so i checked all vacuum and used alldatadiy.com vacuum hose diagram to see if there any issues... then i noticed that pcv tube was all loose like it won't sit well just movable easily and little cracked but not leaking any oil just on bottom near the valve. so should i replace it anyway? and that bracket thing aka connector of all/most vacuum line seem very dirty - cover debris, mud, duct taped, dual clamped, etc. so i remove it and clean it up and remove duct tapes. and remove two clamps and its come off very easy. then afterward that tube where duct tape was cover is cracked so i think maybe i should replace that bracket connector? so is that possible why engine won't running well on idle and had to keep feeding on gas? here's my pics to help my terrible grammar more clear that bracket connector I'm talking about pcv duct taped with 2 clamps edit: maybe its possible why my engine running lousy because of faulty tps/or IAC?
JACKED88 Posted August 20, 2010 Posted August 20, 2010 Vacuum leaks will make it run rough and or not idle right. Without more info I can't guarantee thats your problem but all of your vac leaks should be repaired. So yes. Replace whatever pcs are necessary to repair the leaks.
comanche12 Posted August 20, 2010 Author Posted August 20, 2010 true but is there any store/website/etc. that have parts to replace that bracket connector for vacuum hoses thingy?
gl1200aman Posted August 20, 2010 Posted August 20, 2010 I have not seen any. You will have to try the junk yards or other members. Try posting it in the wanted section.
JACKED88 Posted August 20, 2010 Posted August 20, 2010 true but is there any store/website/etc. that have parts to replace that bracket connector for vacuum hoses thingy?Never seen one but that doesnt mean there isnt one. It's likely gonna be a dealer item or one you'll have to search your local junk yard for.
comanche12 Posted August 21, 2010 Author Posted August 21, 2010 dang but alright i just cleaned it up and remove broken hoses stuck inside and hook everything back on. its look like almost new plus got new pcv too. its sit much better. i gott need new battery because i sent it to autozone to recharge it and its fail so i gotta replace it but i kind don't believe to autozone since they tend said it need replace thats all... new pcv and better connect
fiatslug87 Posted August 21, 2010 Posted August 21, 2010 If you want new lines here are the parts from NAPA. 7151367 from cover to bracket $25 7151366 from bracket to air box $25 7151365 from cover to air box $10
