Emissions Maintenance Timer FREE
btm24
MrFreeze5 is correct. Once they trip, they cannot be reset. The timer is now a paper weight.
The O2 sensor does not need to be replaced though. AMC/Chrysler at the time wanted you to replace the O2 every 60k as preventative maintenance and to get the most out of the mpg's. I just replaced mine whenever it went bad and threw this timer is the dumpster. You might have to also yank the bulb, I honestly forget if I did or not. That bulb is now a spare. :chillin:
  MrFreeze5 said:
If you plugged it in, and the emissions light came on, the timer needs to be replaced along with the 02 sensor, and other periodic maintenance. Its junk now.
no guys its newer its not bad just took off my dash it fell out and now I'm giving it away for any body who wants it thanks tho
  • 1 year later...
Archived
