STERLING STINGER Posted August 15, 2010 Share Posted August 15, 2010 I've been reading my gas mielage for a few days now. i average 9.6 - 14mpg. i even tried to keep it under 2000 rpms as much as possible. i puled a light trailer and ran the air, as usual... and like i said, i babied it too. i guess I'm just trying to see if this is normal, and if not, how do i get better mileage. besides getting smaller tires. thanks, Paul Link to comment Share on other sites More sharing options...
Dave Stark Posted August 15, 2010 Share Posted August 15, 2010 Those numbers look about right to me, I never got better then 10mpg in my XJ with a 2" lift & 31's. They aren't exactly aerodynamic & these 4.0's are certainly thirsty... Link to comment Share on other sites More sharing options...
Automan2164 Posted August 15, 2010 Share Posted August 15, 2010 With oversized tires, a/c blasting, and a small trailer, that sounds about right. Things you could do to help yourself out would be a tune up, cold air intake, header... You won't get much, but if your that worried about it, some things to try. Rob L. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted August 15, 2010 Author Share Posted August 15, 2010 cool thanks! oh btw, gas gague is only reading 3/4 full when its full?????? or should i put up a new post? Link to comment Share on other sites More sharing options...
Pete M Posted August 15, 2010 Share Posted August 15, 2010 is your speedometer accurate? Link to comment Share on other sites More sharing options...
gl1200aman Posted August 16, 2010 Share Posted August 16, 2010 The 88 comanche laredo, with 4.0 5spd, I drove back from NV. got 20+ mpg but that was with no a/c running. at 65-70mph in 55-65 deg. temp was 20 mpg. When it got warmer (70's) I had to slow to 60 mph to keep the temp around 210 or lower (found out later no thermostat) and then got 21 mpg. Link to comment Share on other sites More sharing options...
beepbeepmyredjeep Posted August 16, 2010 Share Posted August 16, 2010 I manage to get about 23 mpg with my MJ. However, it is a manual transmission, no power steering, no A/C, 2.5L 4 cylinder. I guess that really shows how big a difference auto trans, (I'm assuming power steering?), 4.0L 6 cylinder impacts gas mileage. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted August 16, 2010 Author Share Posted August 16, 2010 yes it is pete is your speedometer accurate? Link to comment Share on other sites More sharing options...
