Brake bleeding
Have been having trouble with the brake system. I have replaced the pads, calipers, master cylinder, booster, and have cleaned out the front prop valve (but could not get the valve body out no matter what I tried).
I have bled the brakes 10 times and still get a spongy pedal when I crank the jeep. I bench bled the master cylinder before install, and have put a pressure bleeder on the MS tank while cracking the screws on the prop valve to let any air out. The brake light (dash cluster) comes on when I press the pedal hard. I still have my (operable) load sensing valve in the back, and have bled it as per the shop manual.
The only item I have not replaced is the prop valve, and I cannot find a new (or rebuilt) one anywhere.
Any ideas or suggestions are greatly appreciated.
Jake
You replaced the calipers... Did you make sure the bleeder was on top, and not the bottom?
Easy oversight... Just have to ask.
Rob L.
Good point Rob...I actually went and checked. Yeah, they are right.
What order did you bleed them in? It should be r rear then l rear followed by r front and finally l front. Wrong order may leave air.
Yeah that was the order. I then bled the load sensing valve and did them all again.
Well, the problem turned out to be simple - the line on the front of the prop valve was tight, but there was a crack in the flare on the end of the line that was allowing fluid to escape and air into the system.
Replaced the line and presto - good brakes!
thanks for all the assistance!
