btm24 Posted August 12, 2010 Posted August 12, 2010 Year:1989 Make:Jeep Model:Comanche pioneer 2wd Image: Engine: 4.0 I6 Trans: audo Transfercase: none Front axle: none Rear axle: dana 35 Wheelbase: 119 in Build date: August 26th 1988 Current Location: Zephyrhills Florida Status:on the road Project Notes:2wd still has beanch seat stock hight with 31" tires Current owner: Brandon Meier 3rd owner
btm24 Posted May 2, 2011 Author Posted May 2, 2011 Ford 8.8 rear end now with 4:10 gears not 3:55. Brandon
JMO413 Posted May 30, 2019 Posted May 30, 2019 *E1 Cloth Bench Seat -SA Charcoal 141 Zone 41-Cincinatti 1AA U.S. Dealer Retail 4EA Sold Vehicle 5AM Largo Tracking 5KM AMES Department Stores ALM Longhorn Southfork Package APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Elec,Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2X STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJM 15X7.0 Chrome Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Body Model TM61 Build Date 9/12/88
