I'm looking for replacement seats for my Comanche I saw that early Cherokee seats had the same narrow mounting rails and therefore interchangeable my Question is are 97+ Cherokees the same narrow rail interchangeable seats?
1994 was the change year for XJ seats, so 1993 and below XJ seats are bolt-in. From a 2-door XJ preferrably since they tilt forward. The newer seats require modification.
Wrong.
While the tracks may be the same, the bases are different and the swap is NOT a bolt-in.
You need to grind, drill, cut the tack welds and rivets, then bolt/weld the swapped over bases.
Yep, I should have clarified this better. The XJ 86-93 bucket seats will bolt into an MJ IF you swap the MJ brackets (bench or bucket) to the XJ buckets. Or do as mkbruin stated and swap the bases.
