mvusse Posted July 27, 2010 Share Posted July 27, 2010 1986 Jeep Comanche No photo I'm guessing 2.8V6, no idea on transmission. 2wd, D35 rear long bed (only size available in 86) Build date: Forgot to look Current Location: Canton Pull-a-Part, Canton, OH Status: In junkyard Notes: Got T boned, but has an brand new looking blue paint job. Guessing V6 based on dual tail pipes, but engine, transmission and exhaust back to rear axle are missing. Has the stock 2wd front axle, using stock shock mounts, but running leaf springs. Perches welded to bottom of tube, spring mounted to stock lower control arm mount and shackle hanging just behind the bumper. Bumper is off an import (Toyota?) truck which sticks out 6" more making room for the leaf spring shackle mount. Upper control arm mounts and sway bar are missing. 138,800 miles. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 20, 2019 Share Posted May 20, 2019 Build date: 12/7/85 Link to comment Share on other sites More sharing options...
JMO413 Posted June 28, 2020 Share Posted June 28, 2020 Body Model TL62 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ CGX Head Restraints-Outboard Seating, RR DDJ 5SPD MANUAL TRANS A881 (JA-41) EPD ENGINE - 2.5L I4 TBI GAS HCC HEATER W/UPR LEVEL VENTIL - TYPE II LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) Link to comment Share on other sites More sharing options...
