How much of a difference is there between the MJ and XJ tanks? can a XJ tank be made to fit in my comanche? trying to get around the fuel pump issue. If i can make the XJ tank fit i won't have as much of a problem finding another pump sender unit if i have another problem down the road.
whilst this is posted... is there any way or has anyone tried to fit a tank in the spare tire space? xj zj cj tj somthing one can get at a jy, something to use as an aux. tank?
Shelbyluv fit a TJ tank in his MJ and used a TJ pump/sender.
Jeepman fit a 15 gal dakota tank in his MJ and used a 97+ XJ pump/sender.
Of course, these tanks were used with the 97+ XJ drivetrain swap. Perhaps the fuel pump/sender of all XJs are about the same and could be retrofitted to the dakota tank.
I have only done some reading and have not studied the tanks personally.
