kastein Posted August 4, 2010 Share Posted August 4, 2010 down south that truck shouldn't be so rusty... unless it was originally from somewhere else, or was driven on the beach a lot. That sender is really gross - you're sharq on NAXJA right? This looks familiar :thumbsup: Link to comment Share on other sites More sharing options...
shark Posted August 4, 2010 Author Share Posted August 4, 2010 down south that truck shouldn't be so rusty... unless it was originally from somewhere else, or was driven on the beach a lot. That sender is really gross - you're sharq on NAXJA right? This looks familiar :thumbsup: This jeep had been sitting near the coast in clearwater for who knows how long. salt air i guess?? you should have seen the old gas i poured out of the tank today. nasty stuff. dark brown like guiness but no head. and yes, i am sharq on naxja. some douche who had 2 posts in back in 2004 registered the username shark. they won't give it to me because they said they don't delete usernames ever. i tired to get them to give it to me after i got tired of the username tigerShark. now i don't feel bad that I'm not a paying member anymore. maybe if my name was in red they might think about it. whatever. Link to comment Share on other sites More sharing options...
shark Posted August 5, 2010 Author Share Posted August 5, 2010 just bought this coolant overflow bottle off ebay for $2 plus shipping to replace the ugly old overflow bottle. http://www.summitracing.com/parts/JZP-602-025-01/ i think I'm going to put it where the vapor canister is now and use a newer style box canister from a newer XJ and run the lines to the box under the cad somewhere. or i can put the bottle up front where the battery is now after i relocate the battery under the bed. I'm trying to clean up the engine compartment. Link to comment Share on other sites More sharing options...
shark Posted August 5, 2010 Author Share Posted August 5, 2010 Thinking about this for my new headliner material. http://www.denverfabrics.com/catalog_it ... tmID=BF307 pulled out the old bare panel yesterday along with all the interior panels so i can clean them a bit easier. Link to comment Share on other sites More sharing options...
KCsurfer420 Posted August 18, 2010 Share Posted August 18, 2010 So where can i source a working fuel sending unit? I see that you guys are saying that the senders from the xj,s don't work in the mj's.... what is the diffrance? reason I'm asking is that my pump works fine but the guage has never worked... I was thinking about pulling it out and taking some emeory colth to the contacts.... I'm hoping this will solve my problems....... hum :???: Link to comment Share on other sites More sharing options...
Gjeep Posted August 19, 2010 Share Posted August 19, 2010 I think the senders between common year MJs and XJs are the same and are interchangable. I'll be getting into this more in a couple weeks when I pull a 91 XJ sender/ pump assembly and see in person. If you search online for photos of 91 XJ fuel sending unit and compare the image to your MJ sender it looks identical. Link to comment Share on other sites More sharing options...
shark Posted August 19, 2010 Author Share Posted August 19, 2010 So where can i source a working fuel sending unit? I see that you guys are saying that the senders from the xj,s don't work in the mj's.... what is the diffrance? reason I'm asking is that my pump works fine but the guage has never worked... I was thinking about pulling it out and taking some emeory colth to the contacts.... I'm hoping this will solve my problems....... hum :???: the xj senders do work. I'm sure any obd1 xj sender unit will work with your gauge if you have a '91 like me or then renix with renix . from what ive read, its the length of the unit that poses the problem. the mj tank is too deep for the xj pump/sender unit. the xj unit doesnt reach down into the tank far enough. theres a guy on here that modded the xj unit to compensate for this. am i correct on this? if not, someone please clear this up. Link to comment Share on other sites More sharing options...
drase Posted August 21, 2010 Share Posted August 21, 2010 I remember seeing this MJ on CL. I'm glad u rescued it. Nice XJ. Link to comment Share on other sites More sharing options...
kastein Posted August 24, 2010 Share Posted August 24, 2010 it's the metal bracket / frame / bulkhead thing that the pump and sender attach to that are not compatible cross-MJ/XJ lines. The wire arm that connects the float to the sender itself may also be different but I'm not sure. Link to comment Share on other sites More sharing options...
shark Posted November 19, 2011 Author Share Posted November 19, 2011 I know its been a while since ive updated but that doesnt mean i havent been hard at work on this thing. This has turned into a bigger project than i thought it would be because i decided to tear everything down and restore or replace everything. Painting some Grizzly's I found on Craigslist. Prep Link to comment Share on other sites More sharing options...
shark Posted November 19, 2011 Author Share Posted November 19, 2011 Fixing some rot under the hood. Link to comment Share on other sites More sharing options...
shark Posted November 19, 2011 Author Share Posted November 19, 2011 Got a new door. I need a driver's door if anyone has one local. I need a 97+ w/ power windows/lock and gray interior. Link to comment Share on other sites More sharing options...
shark Posted November 19, 2011 Author Share Posted November 19, 2011 Time to paint the engine compartment and the motor. Link to comment Share on other sites More sharing options...
shark Posted November 19, 2011 Author Share Posted November 19, 2011 My adult ADD took over and i decided to build a blasting cabinet to clean up the other under hood components. Link to comment Share on other sites More sharing options...
shark Posted November 19, 2011 Author Share Posted November 19, 2011 Score! Brand new carpet from a guy on ebay. half price. maybe ill get it install it someday. new header. Junkyard score! Very nice tailgate. Replaced these... Link to comment Share on other sites More sharing options...
shark Posted November 19, 2011 Author Share Posted November 19, 2011 I built a battery box to mount into the spare tire location. It uses the existing bolt holes. Link to comment Share on other sites More sharing options...
shark Posted November 25, 2011 Author Share Posted November 25, 2011 Still workin' Link to comment Share on other sites More sharing options...
shark Posted November 25, 2011 Author Share Posted November 25, 2011 Making progress... Cap, rotor and wires from Summit Racing. Accel coil. Link to comment Share on other sites More sharing options...
