FLMANCHE526 Posted July 13, 2010 Share Posted July 13, 2010 How Much to do a complete rebuild while also turning it into a stroker? I'm Buying a 89 2wd sb auto 4.0 and want to make it a fast street truck and want to keep a jeep engine in it. Any tips and pointers will be appreciated. Thanks Link to comment Share on other sites More sharing options...
DJM/78 Posted July 13, 2010 Share Posted July 13, 2010 A stroker is a complete engine rebuild , done right anyway it will cost a little more than just rebuilding with stock specs , larger injectors are not a must but if you intend to actually get any power out of it I would do that as well . I would also look for a high output motor to get the true benefit of all the 96+ plus upgrades like the 97+ intake and other little goodies that will push some pony's . IMHO , just swap a V8 in it and be done . Link to comment Share on other sites More sharing options...
FLMANCHE526 Posted July 13, 2010 Author Share Posted July 13, 2010 I wouldnt mind putting in a v8 But id really like to keep the 4.0 in it so its a sleeper :thumbsup: Link to comment Share on other sites More sharing options...
DJM/78 Posted July 13, 2010 Share Posted July 13, 2010 Yeah , I'm doing a stroker build to the 92" eventually , probably when the motor goes , hopefully a long time from now .... :chillin: Link to comment Share on other sites More sharing options...
sinkrun Posted July 13, 2010 Share Posted July 13, 2010 Check this out TONS of info I am building one also just have got far at all(motor is sitting there waitng for me to start). www.JeepStrokers.com Link to comment Share on other sites More sharing options...
Blue XJ Posted July 13, 2010 Share Posted July 13, 2010 I built my stroker about 4 years ago. I have just under $3,000 into it. About $1300 of that is the machine work that I had done. The only parts that I reused were the block, head, valve cover, oil pan and front cover. All the other components, including the valve train were replaced. Link to comment Share on other sites More sharing options...
cracker Posted July 13, 2010 Share Posted July 13, 2010 $3000 is about right with good parts. Link to comment Share on other sites More sharing options...
