STERLING STINGER Posted July 12, 2010 Share Posted July 12, 2010 any threads here on how to replace a trani mount? thanks paul Link to comment Share on other sites More sharing options...
cracker Posted July 12, 2010 Share Posted July 12, 2010 It is about as basic as swapping out your oil. Support the transmission, pull the crossmember, unbolt transmission mount, put new transmission mount in, and replace the crossmember. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 12, 2010 Author Share Posted July 12, 2010 thanks ive never done it before so i thought id ask :thumbsup: Link to comment Share on other sites More sharing options...
88 Beast Posted July 12, 2010 Share Posted July 12, 2010 I replaced mine without dropping crossmember. Just jack trans. up far enough to clear the crossmember. Piece of cake. Link to comment Share on other sites More sharing options...
smithe1811 Posted July 13, 2010 Share Posted July 13, 2010 88 Beast said: I replaced mine without dropping crossmember. Just jack trans. up far enough to clear the crossmember. Piece of cake. thats the way my book says to do it.... Link to comment Share on other sites More sharing options...
kyleag89 Posted July 13, 2010 Share Posted July 13, 2010 Hey Paul, make sure you buy a decent mount. I bought one for $35 from Advance auto parts about 3 months ago and it just started making creaky and squeaky noises. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 13, 2010 Author Share Posted July 13, 2010 i got it from the dude above you...well your post.....hey erik....whered u get it? :dunno: Link to comment Share on other sites More sharing options...
smithe1811 Posted July 13, 2010 Share Posted July 13, 2010 i ordered it through autozone, i believe the company is dui. Erik Link to comment Share on other sites More sharing options...
cracker Posted July 13, 2010 Share Posted July 13, 2010 88 Beast said: I replaced mine without dropping crossmember. Just jack trans. up far enough to clear the crossmember. Piece of cake. Funny. I couldn't lift my transmission enough to get in there on my XJ or my MJ (with the modified floor pan). No biggie. The crossmember adds an additional 15 minutes or so. Link to comment Share on other sites More sharing options...
88 Beast Posted July 13, 2010 Share Posted July 13, 2010 15 min. quicker to Beer:30 :cheers: Link to comment Share on other sites More sharing options...
kyleag89 Posted July 14, 2010 Share Posted July 14, 2010 HUH WHAT!? You don't drink while working on your MJ? :nuts: Link to comment Share on other sites More sharing options...
88 Beast Posted July 14, 2010 Share Posted July 14, 2010 Too hard to drink laying on my back. Quess I need to practice more :cheers: Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 15, 2010 Author Share Posted July 15, 2010 just finished it up...bout half hour forty five mins...crossmember has 8 bolts and they sucked to get off. still got a knocking down there...sounds like a shock but it aint.....motor mount maybe? no clue Link to comment Share on other sites More sharing options...
Northup Posted July 15, 2010 Share Posted July 15, 2010 does it only make the sound while moving or traveling over a bump? I had a similar sound on my YJ replaced the shocks and tranny mount. Found out the sound was coming from my track bar. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 15, 2010 Author Share Posted July 15, 2010 Northup said: does it only make the sound while moving or traveling over a bump? I had a similar sound on my YJ replaced the shocks and tranny mount. Found out the sound was coming from my track bar. yes exactly..but the track bar seems tight....I'm gonna replace it. :nuts: Link to comment Share on other sites More sharing options...
Northup Posted July 15, 2010 Share Posted July 15, 2010 can you tell if the sound is coming from the rear or the front? Link to comment Share on other sites More sharing options...
kyleag89 Posted July 15, 2010 Share Posted July 15, 2010 Not to Hi jack but mine is doing this too.. Thought it was the cheap trans mount I got from Advance auto parts. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 15, 2010 Author Share Posted July 15, 2010 it sounds to me like its right in the middle, where youd rest your right arm while driving....I'm leaning towards control arms but idk for sure. i don't wanna have to replace the track bar cuz it seems fine. :dunno: it only makes the sound while traveling over a bump. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 15, 2010 Share Posted July 15, 2010 This is where uni-bodys SUK!!! They transmit noises to the far reaches of the body... making diagnosis darn near impossible.... That being said, CAs are a good guess. If your gonna stay with stock arms, don't even think of replacing the bushings... Complete factory arms, with bushings are not very expensive!! As a mater of fact, if you do have me weld up your links, I have a couple sets of upper CAs. I'll throw two of the best ones in the box for the return trip... CW Link to comment Share on other sites More sharing options...
maddzz1 Posted July 15, 2010 Share Posted July 15, 2010 I had a clunk/knock I couldnt find. Thought it was the trac bar also but turned out to be Tie rod end at the pitman arm Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 15, 2010 Author Share Posted July 15, 2010 just replaced both.. cw, i can get control arms from parts store..thanks though. is there a.y special way to take them off...they look pretty simple..but again idk for sure. thanks paul Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 16, 2010 Share Posted July 16, 2010 ONE AT A TIME!! That and have a good sized stilson wrench handy!! CW Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 16, 2010 Author Share Posted July 16, 2010 stilson wrench? i have a torch and sockets..lol ill have to google it. thanks Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 16, 2010 Author Share Posted July 16, 2010 i call them monkey wrenches :banana: Link to comment Share on other sites More sharing options...
