valis Posted July 20, 2010 Share Posted July 20, 2010 The spray gasket remover that I use is a clearish, nasty liquid. It'll burn if it touches your skin. To get rid of the sludge in the pan - use gasoline, kerosene, or diesel. I have a parts washer filled with kerosene that I've been using for the last three years to clean some of the nastiest, oiliest crud on the planet. I really need to drain it, clean it and refill but I can't complain about the price vs. effectiveness vs. longevity of the stuff. Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 20, 2010 Share Posted July 20, 2010 I've had good results with this, sometimes it takes an application, scraping then reapplication. http://www.jamestowndistributors.com/userportal/woeimages/Engine/8621.jpg Link to comment Share on other sites More sharing options...
xjrev10 Posted July 20, 2010 Author Share Posted July 20, 2010 I've had good results with this, sometimes it takes an application, scraping then reapplication.http://www.jamestowndistributors.com/userportal/woeimages/Engine/8621.jpg looks to be the same stuff that i used. its like a white gel stuff. i was covered in the stuff when i was trying wipe it onto the bottom of my engine. napa just had their name on it. Link to comment Share on other sites More sharing options...
kastein Posted July 26, 2010 Share Posted July 26, 2010 I generally solve all my problems with a good soak + scrub in gasoline and then hose it off with brakleen afterwards. If you use a wire wheel on things, use a brass one not a steel or stainless steel one, a brass one won't mar the gasket sealing surfaces but will still rip the gasket material off quite nicely. Link to comment Share on other sites More sharing options...
