STERLING STINGER Posted July 8, 2010 Share Posted July 8, 2010 i have no idea how to put my rear flares on....there is bent sheet metal now where the original body was so there is no holes. can't i just drill holes in it and zip tie them on? or does anyone else have any ideas? Â thanks again for the millionth time paul Link to comment Share on other sites More sharing options...
freakjeep93 Posted July 8, 2010 Share Posted July 8, 2010 drill holes and use normal bolts and nuts i think. ive never done it myself... yet Link to comment Share on other sites More sharing options...
maddzz1 Posted July 8, 2010 Share Posted July 8, 2010 I believe the size most people use are 1/4" x 20 bolts with fender washers  Do you still have the metal plates with the studs or did they all brake during removal? Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 8, 2010 Author Share Posted July 8, 2010 no metal platss at all Link to comment Share on other sites More sharing options...
maddzz1 Posted July 8, 2010 Share Posted July 8, 2010 Then you just have to drill the holes and use the bolts/washers listed above. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 8, 2010 Share Posted July 8, 2010 I believe the size most people use are 1/4" x 20 bolts with fender washers Do you still have the metal plates with the studs or did they all brake during removal?  CK my build thread.. this is what I did! I also have some ideas for fender stiffeners...  CW Link to comment Share on other sites More sharing options...
wannabeMJ Posted July 8, 2010 Share Posted July 8, 2010 I believe the size most people use are 1/4" x 20 bolts with fender washer Do you still have the metal plates with the studs or did they all brake during removal? Â what's a fender washer Link to comment Share on other sites More sharing options...
mfpdm Posted July 8, 2010 Share Posted July 8, 2010 what's a fender washer  Midget with a sponge. :D   :cheers: Link to comment Share on other sites More sharing options...
wannabeMJ Posted July 9, 2010 Share Posted July 9, 2010 what's a fender washer  Midget with a sponge. :D   :cheers:  can't seem to find that at the store :dunno: Link to comment Share on other sites More sharing options...
maddzz1 Posted July 9, 2010 Share Posted July 9, 2010 I believe the size most people use are 1/4" x 20 bolts with fender washer Do you still have the metal plates with the studs or did they all brake during removal?  what's a fender washer  Basically a big washer. Check this thread (CWs build) http://comancheclub.com/forums/viewtopic.php?t=1230 The ninth post down (the one after the rock sliders) and there is a pic of CW holding up the sheet metal stiffener he made and you can see one in the pic Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 9, 2010 Author Share Posted July 9, 2010 i got them Link to comment Share on other sites More sharing options...
