jeepjunkee Posted June 29, 2010 Posted June 29, 2010 Just acquired a 90 xj with 4.0 aw4 np242 nondisco front axle 3" lift 31-10.50 baja claws. I was wondering what it takes to build a reliable stroker motor? I am thinking about doing this.
1990 Pioneer 4x4 Posted June 29, 2010 Posted June 29, 2010 This should help! http://www.hescosc.com/shop.asp?action=details&inventoryID=42913&catId=7550 Also, there is alot of chatter on other Jeep forums. With a little time/effort you should be able to find alot of info. :cheers:
Boilermaker Posted June 29, 2010 Posted June 29, 2010 what it takes depends on what you want out of it besides reliability....are you building a rock crawler or street truck? Do you want to run regular or premium gas? Do you have lots of money or are you on a tight budget? Good places to start: Dino Savva's stroker to junker site and his 4.0 performance site. jeepstrokers.com, tons of good info here and knowledgeable people there. if you are unfamiliar with some of the terminology start with the FAQs section. Then read thru the projects section, especially some of the longer threads.
jeepjunkee Posted June 30, 2010 Author Posted June 30, 2010 Thanks for the info guys. I did a little research and found this site. It seems to be my go to site very nicely laid out with part numbers and etc. http://www.ajeepthing.com/stroker-motor.html
