DJM/78 Posted June 27, 2010 Share Posted June 27, 2010 I'm almost done with my timing chain on the 2.5 L , so again I refer to the masters of the MJ on a oil sling , needed or not ? A buddy of mine said he threw his away , wasn't needed but I figured I'd check with you guys first before I pitched it . Link to comment Share on other sites More sharing options...
Eagle Posted June 27, 2010 Share Posted June 27, 2010 I'm almost done with my timing chain on the 2.5 L , so again I refer to the masters of the MJ on a oil sling , needed or not ?A buddy of mine said he threw his away , wasn't needed but I figured I'd check with you guys first before I pitched it . Your friend is, I assume, a professional automotive engineer? Ask him why, if the oil slinger isn't needed, the engineers at AMC/Chysler/Jeep went to the trouble and expense of using it. They don't use ANYTHING without a reason if it'll save 2-1/2 cents per vehicle. Link to comment Share on other sites More sharing options...
DJM/78 Posted June 27, 2010 Author Share Posted June 27, 2010 Thank you Eagle , thats what I thought , I knew the chain needed lubrication somehow and I couldn't find anything that was actually doing anything but the oil sling . Being a bike fanatic , I clean and lube my chains frequently . Link to comment Share on other sites More sharing options...
deziped Posted June 28, 2010 Share Posted June 28, 2010 And all this time I thought oil slingers just moved the oil away from the seal area. Link to comment Share on other sites More sharing options...
jimoshel Posted June 28, 2010 Share Posted June 28, 2010 Keeping oil from the seal is their primary purpose. Slinging it all over the place is just a side benefit. Link to comment Share on other sites More sharing options...
Geonovast Posted June 28, 2010 Share Posted June 28, 2010 Why would anyone consider tossing it? It weighs nothing, and would be an unnoticeable reduction in rotating mass. Along with its functions mentioned above, I always saw it as (and this is EXTREMELY unlikely), but what if your crank's timing gear decided to walk forward? Nothing stopping it if you toss that. Link to comment Share on other sites More sharing options...
DJM/78 Posted June 28, 2010 Author Share Posted June 28, 2010 Thats what I figured , thanks guys its going back on . :thumbsup: Link to comment Share on other sites More sharing options...
