Automan2164 Posted June 12, 2010 Share Posted June 12, 2010 1991 Jeep Comanche Sportruck 4.0L HO/AW4/NP231/D30 disco/D35/SWB Build date: 9/90 Current Miles: 234,906 Current Location: Nothern IL/ Southern WI Status: Picked up with hopes to save, but condition is too bad. Jury is still out on this one. Notes: Drivetrain is questionable at this point. Makes a bad rattle, possibly from the trans. Does not move under its own power, and sounds horrid. VERY RUSTY. Blue exterior, with light tan bench interior, column shift with tilt. Late model Sportruck decals. Weird aftermarket hitch, with a load distributing bar to the rear crossmember under the bed. Current owner: Rob L and Pat P. Rob L. Link to comment Share on other sites More sharing options...
btm24 Posted October 6, 2010 Share Posted October 6, 2010 rust much? :eek: Link to comment Share on other sites More sharing options...
JMO413 Posted May 25, 2019 Share Posted May 25, 2019 *C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT -Y6 DARK SAND 151 Zone 51-Chicago 1AA U.S. Dealer Retail 4XU Quad Seat Credit ALA SE Decor Group APA Monotone Paint BAF 130 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRV Left Manual Mirror GUA Open HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers K3Z STRIPE/BADGE/MOLDING/COLOR KDP STRIPE/BADGE/MOLDING COLOR KWA STRIPE/BADGE/MOLDING/COLOR LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PB8 MIDNIGHT BLUE MET CC PRI PNT - HB8 QB8 SECONDARY PAINT RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z82 Right Front Spring Group XI Body Model JL61 Build Date 9/23/90 Link to comment Share on other sites More sharing options...
jdog Posted February 1, 2021 Share Posted February 1, 2021 Selling Dealer: VILLAGE JEEP-EAGLE INC Elgin, IL Link to comment Share on other sites More sharing options...
