mvusse Posted June 10, 2010 Share Posted June 10, 2010 Where can I get one, or something else that works? Link to comment Share on other sites More sharing options...
Jakeman17 Posted June 10, 2010 Share Posted June 10, 2010 go to auto parts store and make something work Link to comment Share on other sites More sharing options...
Jakeman17 Posted June 10, 2010 Share Posted June 10, 2010 here's what i did Image Not Found Link to comment Share on other sites More sharing options...
fiatslug87 Posted June 10, 2010 Share Posted June 10, 2010 If you want new lines here are the parts from NAPA. 7151367 from cover to connector $21.99 7151366 from connector to air box $21.99 7151365 from cover to air box $8.69 Link to comment Share on other sites More sharing options...
bigd44889 Posted June 10, 2010 Share Posted June 10, 2010 i got rid of that hose and put a breather in it works good will the one off a 2.5 valve cove work if so i can send u one or bring it to u at jeep skool Link to comment Share on other sites More sharing options...
mvusse Posted June 11, 2010 Author Share Posted June 11, 2010 After looking around Autozone, NAPA and two Advance Auto Parts stores I came up with Dorman/Help! part number 47034, marked as a "PCV system elbow" for GM vehicles. The 1" end fits perfectly in the valve cover. The 5/8" end is a bit too large to fit well on the tube, but a hose clamp fixed that easily enough. $4.59 Problem solved. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 11, 2010 Share Posted June 11, 2010 After looking around Autozone, NAPA and two Advance Auto Parts stores I came up with Dorman/Help! part number 47034, marked as a "PCV system elbow" for GM vehicles. The 1" end fits perfectly in the valve cover. The 5/8" end is a bit too large to fit well on the tube, but a hose clamp fixed that easily enough. $4.59 Problem solved. Great solution. :cheers: I looked up that Dorman part and it's a push-in grommet type elbow. The newer valve covers (at least my 91 alloy cover) uses a 1/4-turn lock twist lock elbow, kind of like the oil filler cap. If you know of a Dorman replacement that will work for these covers please post it mate. Gracias. :D Link to comment Share on other sites More sharing options...
mvusse Posted June 11, 2010 Author Share Posted June 11, 2010 Sorry, no clue on that one. just the 87 through 90 ones. Maybe at some point I will have to find something for either my 94 or 96 Cherokee, but they are both still fine so far. Link to comment Share on other sites More sharing options...
