1J7FJ26S5NL196578
DJM/78
92" Comanche :
Specs : 92" , 4.0 HO , AX15 , NP231 , D30/35 , SWB .
Build date : 2-92"
Status : Currently being completely restored and modified as well as DD . Sitting at 200,000 miles on motor and trans. , the rest of the drivetrain has been replaced .
Suspension , steering and axles have 1k miles them so far .
Notes : I bought the truck in Sept. of 09" , since then it has been a very reliable truck . Truck was completely stock with no modification , this is the list of things I've done since
Sept. : RE 5.5 HD lift , Tera Flex high steer kit , sway bar brackets and SOA kit . Tom woods drive shafts , rebuilt stock non disco D30 with 456 gears . Rear is a swapped in
89" XJ D44 with Trac-Loc , axle is completely rebuilt w/ alloy shaft , Yukon 456 gears and Tera Flex disc brakes . Other upgrades are , 31" inch tires , 15x10 " D " window wheels , Custom TJ seats , XJ console conversion and a couple of 96" + upgrades here and there .
Owner : Dave M. AKA DJM/78
  • 8 years later...
*C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT
-SA Charcoal
174 Zone 74-Denver
1AA U.S. Dealer Retail
25C Customer Preferred Package 25C
2TC Customer Preferred Package 2TC
3VN Customer Preferred Discount
4M1 Retail to Bid Diversion Tracking
4UA SCA Tissue North America LLC
ALA SE Decor Group
APA Monotone Paint
BAP 75 Amp Alternator
BCC Dual 730 Amp Maint Free Batteries
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAY DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KER
KWR STRIPE/BADGE/MOLDING/COLOR
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAF High Altitude Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PE9 DARK CORDOVAN PEARL COAT PRI PNT - EE9
QE9 DARK CORDOVAN PEARL COAT SEC PNT - EE9
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCG Leather Wrapped Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TMW P265/60r18 BSW A/S All Terrain Tires
TZA Goodyear Brand Tires
WJN 15" Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z65 Left Front Group XIV
Body Model JL61
Build Date 2/11/92
  • 1 year later...
