1J7FJ26LXLL113166
Automan2164
1990 Jeep Comanche
4.0L / AX15 / NP231 / D30 / D35 / LWB
110,000 Miles as of 6-2010
Build date:
Current Location: Northern IL
Status: Project, awaiting H.O. swap from MJ 1J7FJ26S1NL159270
Notes: Blown engine, number 5 cylinder bad, but awaiting drivetrain and harness swap. Grey bench interior with idiot light cluster. P.O. swapped in three spoke maroon steering wheel because it looked better. Gambler wheels. Dark metallic silver in color.
Current owner as of 6-2010: Rob L. AKA automan2164
Rob L.
  • 1 month later...
  • 8 years later...
*X1 TRIM STYLE X1 - CLOTH BENCH
-SA Charcoal
141 Zone 41-Cincinatti
1AA U.S. Dealer Retail
ALA SE Decor Group
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KWX DK QUARTZ - BADGE - "INTREPID" - DECKLID
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
PS3 DOVER GRAY MET CC PRI PNT - HS3
QS3 DOVER GRAY MET CC SEC PNT - HS3
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z65 Left Front Group XIV
Z84 Right Front Spring Group XIII
Body model JL62
Build Date 8/7/89
  • 1 year later...
