henryuu Posted May 28, 2010 Posted May 28, 2010 had a question for u guys. would a xj 4cyl tc fit a mj 6cyl?
Pete M Posted May 28, 2010 Posted May 28, 2010 which tc? torque converter or transfercase? 4.0 or 2.8 6 cyl? If transfercase, what year is the 6 cyl and is it stick or auto?
henryuu Posted May 29, 2010 Author Posted May 29, 2010 not sure what tc it is. the transfer case its on a 87 xj 4cyl 4 speed manual. my mj is a 89 6cyl 5 speed manual. :???:
Oizarod115 Posted May 31, 2010 Posted May 31, 2010 we need to know which 5 speed you have because 89 was a cross-over year. if you have the puegot then yes it will fit if you have the AX15 then no it will not fit.
Geonovast Posted May 31, 2010 Posted May 31, 2010 It will not fit. The 4 cylinder manual transmissions (AX-4/5) used a long shaft input on the transfercase. Pukey and AX-15 need a short shaft.
henryuu Posted May 31, 2010 Author Posted May 31, 2010 ok well does the belhousing match between the 2 then. is it stamped on the tranny,antidisestablishmentarianism kinda tranny it is?
Automan2164 Posted May 31, 2010 Posted May 31, 2010 4 cylinder and 6 cylinder bell housings are NOT compatible. Rob L.
