Air Intake Hose
I'm not exactly sure what this part is called, but what I'm talking about is the flimsy coil-like hose that runs between the air filter box and the throttle body. Mine is in pretty rough shape and I was wondering what people are using for replacments? Can you use someting else or do most people get a new one from the dealer (if available)?
I would either use this as the time to get an intake kit, which does away with it, or just pick one up from a member/Junkyard.
Rob L.
most of the intake kits i've seen re-use that hose unless you know of some that do come with it (I'm out of touch)
check the junkyard for sure, should be cheap
Rob L.
http://www.autopartswarehouse.com/detai ... 71519.html
Must be out of touch. :D
Rob L.
