ohiostate454 Posted May 25, 2010 Share Posted May 25, 2010 Any body with a cheap Comanche in or around Michigan i would like to get one to restore. Preferable not a basket case but if the price is right maybe any thing under a grand is good with 4wheel drive, nothing else matters Link to comment Share on other sites More sharing options...
Pete M Posted May 25, 2010 Share Posted May 25, 2010 Go south. the further the better. :thumbsup: Down there you can get a rot-free truck that may or may not run for 600 or less. :yes: Don't start with a northern truck is you intend to restore. the rust will never go away completely. Oh, and the 4wd swap is pretty much bolt in. Don't limit yourself by skipping over solid 2wds. :thumbsup: Unless of course you're intending to let this truck touch ice and snow. In that case, just use a northern truck since it'll rot out from under you either way. My 86 was completely rust free when I bought it. a couple winters cured that for me. :( Link to comment Share on other sites More sharing options...
XXLMJ Posted June 29, 2010 Share Posted June 29, 2010 You still looking for one? Link to comment Share on other sites More sharing options...
idahoeagle Posted July 9, 2010 Share Posted July 9, 2010 I decided that mine's up for grabs again... 87 shortbed 4.0/AX15/231/44 with a new fuel tank/tach instrument cluster/ no rust from western Idaho, currently in Wyoming... Link to comment Share on other sites More sharing options...
